RobWNY wrote:
MrWizard, 4 batteries was my original plan but SoundGuy thought it was way more than what I would need. Now I'm only more confused. There seems to be a difference of opinion on how much power is needed. When I get the prices of the Trogan AGM batteries, I'll buy what I can afford.
It's unfortunate you're "confused" as the issue really is quite simple. :) This entire discussion started with you saying you almost always camp on electric sites, sometimes even full service sites, only seldom dry camp, but are now planning a 4-day dry camping trip in the fall with friends. To that end you've since purchased a new 3000 watt genset and are now planning on replacing your single flooded battery with FOUR 6 volt GC-2s, originally flooded IIRC, but now with much more expensive AGMs - in total a significant investment. :E Yes, you've since clarified your retirement plans
may (or may not) include more dry camping but at this stage you say you have
no idea just what your dry camping power requirements might be, nor have you said anything about how you would mount 4 batteries (which in itself may involve spending even more $$$), nor AFAIK are you even considering an inverter which itself could then justify the expense of 4 GC-2s over just 2. JMO, but
your approach of simply throwing your wallet at a problem to make it go away is what is "confusing", especially since you have the option before you of starting with just 2 6 volt batts and seeing how it goes ... if after a few dry camping trips that proves need for 2 more batts then so be it, at least you then
know what you're up against.
In a previous post
MrWizard said -
"i've never meet anybody who said they had two much battery power
and they should have bought less batteries" ...
Well, I have - ME! ... and the countless others, including yourself, who
mostly camp on electric sites, only occasionally on dry sites. Upgrading from a single G24 to a single G31, or adding a second G24, or even upgrading to a pair of GC2s is IMO a reasonable intermediate step, but if one later decides more is required then that's the time to go further with it. I've been through this exercise myself, have chosen to just stick with my existing G27, and
load support (4 pics) with my truck those few times each season we may find ourselves without shore power. Eventually that aging G27 will need to be replaced so at that time I'll mostly likely upgrade to a single G31 AGM or at most a pair of GC-2 AGMs, but
no genset because past experience in owning 2 different EU2000i gensets proved how little they were actually used. :R
There are those on these forums more than willing to offer ultimate solutions, more than willing to spend
your $$$$ with recommendations, but will they be there when it's time to pay for all that gear, be there to mount it, to wire it, or pay for whatever other items (such as a better converter or a larger battery box) that may be required to install and better maintain that equipment? The answer to that shouldn't be confusing at all. ;)
