BFL13 wrote:
I pity the poor guy who wants AGMs with just a converter that does whatever it does, and he is stuck with that.
Hey .... I really resemble that remark! ;)
I've intentionally left only the stock Parallax 7345 converter in our 2005 Itasca Class C cuz I think it's a great ~$200 piece of equipment - why fix something that ain't broke.
The motorhome came with two 12V Group 24 wet cells that lasted six months after I bought it due to (I think) mistreatment by the dealer when the rig was sitting on their lot the year before I bought it (I bought the RV "new" in 2006).
I had the dealer (under warranty) install a couple of 12V true deep cycle Group 29 100 amp hour AGM wheel chair batteries with a specified float voltage of 13.6 volts - a perfect match between those AGM batteries and the stock converter. Those two AGMs went about 8 years before I replaced them "just in case" ... they were still functioning fairly well when I got rid of them .
I replaced them with two 12V true deep cycle Group 31 115 amp hour AGM batteries with a specified float voltage of 13.5-13.8 volts - again a perfect match between those AGM batteries and the stock converter. I considered Lifeline AGMs this time around, but when I contacted Lifeline regarding specifications they refused to endorse my use of the Parallax 7345's 13.6-13.8 volts as a float voltage for the Lifelines ... insisting that they would gradually dry out unless I used a float voltage of ~13.2 volts. So instead, I went with a couple of Fullriver AGMs that cost about as much as Lifelines.
My RV AGM batteries see the Parallax converter 1000's of hours per year and the engine alternator a few hundred hours per year. So far, I can't find anywhere statements or data saying that AGM batteries are ruined by not seeing 14.XX volts very much for charging - other than occasionally when exposed to the V10 engine's alternator when traveling. However, I do completely charge them up all the time using this combination of converter plus alternator.
