https://www.youtube.com/watch?v=GC1jIKpC7Zw&list=UUoPqTkOluQsuu3RpGnxVwFw&index=17The above video nicely shows the realtionship between volts and amps on a charging battery.
My Meanwell power supply has only a voltage dial, but can deliver 40 amps until the chosen voltage is reached, at the DC output terminals, then amps taper.
The MAstech power supplies can control volts and amps independently as the video shows.
A converter controls the voltage only. It outputs whatever amperage required, upto its maximum, to reach/maintain the voltage preprogrammed as 'best; for your battery. Once that voltage is reached, on the DC output terminals, then it it is in constant voltage mode/Absorption and the amperage required to maintain tha tvoltage will decline as the battery charges more and more.
When these amps taper to a certain level, then the battery can be considered full charged.
Flooded batteries can be verified with a hydrometer. AGM batteries require this amperage required to maintain absorption voltage as a full charge determinant.
So it all comes down to fully charging a battery
Fully chargng a battery requires time at absorption voltage.
Absorption voltage changes with battery temperature.
Absorption voltage duration varies with the amperage at whcih absorption voltage was attained, and the health of the battery, and of course its state of charge when absorption voltage was reached at the amperage it was accepting from the charging source.
These factors eliminate a one size fits all charger as being perfect for any battery in any given usage at any state of battery health in any temperature.
Really there is so much room for error regarding achieving ideal, it is rather impressive lead acid batteries can last as long as they do.
Which shows this level of obsession is not required.
But one should know what 'Ideal' is, even if they cannot be bothered to aquire the tools and perform the tests, to achieve it.
Lot to be said for just getting product X and replacing batteries when they simply need it
