time2roll
Apr 25, 2015Nomad
+1 for just doing the inverter as power does not seem to be an issue.
If you want to charge direct you will need to discover the actual charging voltage of your solar and compare to the actual charging of the PW battery. Voltage is the issue, not size. Sealed PW battery could be a bit sensitive to overcharging.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
