ABendage
Apr 25, 2015Explorer
westend wrote:
The amperage or current shouldn't be an issue, the battery for the PW will only draw as much as it needs. I'd suggest to make a connection to your existing battery that is ergonomic enough so that you can position the PW close to the battery and attach a pair of charging wires. Anderson Power Pole connectors come to mind.
Perfect! I wasnt clear on how amps worked and worried about overcharging. That must be a voltage concern and the charge controller would regulate that? Anyways, sounds like this will work, I'll just put a pigtail on the battery with the same flat 2 connector the normal charger uses and plug it in. I'll put a 5amp inline fuse in it just to be safe.
Thanks for everyone's help!
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
