BFL13
Feb 06, 2021Explorer II
Kountryguy wrote:
Can I charge AGM batteries with a PD9280 Converter/Charger?
AGMs will have an "initial charging rate" specified limit in amps, often 27amps per 100AH of capacity (C20). Only Lifeline AGMs can take higher amps safely AFAIK.
So your 80 amper would work on 300AH of battery bank or more. Unless you have Lifeline AGMs
The PD9280 needs a 20 amp (120v) circuit with the 20 amp plug of course.
You need to keep hitting the Charge Wizard to keep it at 14.4v till the AGMs are truly full so they are not left undercharged, sulphating. You hold them at 14.4v till amps taper to 0.5a/100AH or 1.5 amps with the 300AH bank.
That means you need an ammeter to observe when the amps get to that amount. I use my Trimetric monitor as the ammeter for that job.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
