CJM1973's avatar
CJM1973
AGM Battery Charging with Solar
This is my first attempt ever at solar so I'm learning as I go.
I've recently installed two 100 watt polycrystalline panels on the roof of my RV. I have a relatively new bank of AGM deep cycle 12 Volt batteries from Weize (three 100 amp hours).
I purchased and use a Victron 712 battery monitor (which works great). I decided to buy a Victron Bluesolar 100/20 amp solar charge controller to harness the panel voltage. The problem I'm faced with is the recommended settings on that controller for my battery type and brand. I'm reading conflicting advice online. Weize has this stickered on each battery:
Cycle use: 14.5 - 14.9V
Stand-by use: 13.5 - 13.8V
I've read that AGMs should be limited to 14.4V during cycle use (I'm assuming this is another name for asorbsion??) and 13.2V for Stand-by use (another name for float charge??)
I've also read that undercharging weakens AGMs more than overcharging. Not sure if this a truly accepted statement.
I'm looking for ideal charging parameters for the longest life of these batteries. In addition, I did purchase the temperature sensor for the Victron SCC.
Any help with these controller settings is much appreciated.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
