HiTech
May 10, 2013Explorer
full_mosey wrote:HiTech wrote:
You never want to either. It is an extreme recovery procedure for an otherwise dead battery. Lifeline has one for batteries that have run dead and some other recovery procedure too. I used only as a last resort and it did work, but guaranteed the battery was stressed. It was not valve noise, it was a bubbling/crackling sound inside the battery.
Jim
Ah! That clears things up considerably. Your AGMs were already ruined. I had a grp31 trolling FLA that I ruined and it sizzled and crackled when I tried to recover it with a VEC1093.
It had run dry over Winter because I brought it inside and used it with an APC 1250 UPS without checking or adding water.
HTH;
John
Little 32 amp hour car AGM. But the recovery procedure actually worked and it is back in service. But at the time I ran the procedure, it would not start the car so Ah capacity and CCA were way down.
I have 2 not really in service yet Deka AGMs and 2 older small SLI AGMs.
Jim
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
