markm's avatar
markm
Charging batteries: inverter vs charger
Going to RMNP next week. No hook ups there, so need to recharge two 6 volt batteries daily. I will be using a Honda 2000 EUi generator. Couple questions:
1. Can I use external charger hooked to batteries while also charging batteries from trailer inverter. This would occur when I plug trailer power cord into generator.
2. Will external charger charge faster than trailer inverter?
Basically, I'm trying to determine the fastest way to recharge the batteries each day.
Thanks, Mark
  • I have questions about charging two 6-volt batteries connected in series using a 40amp portable battery charger.
    1. Do I connect the 40amp battery charger using the pos/neg lead on a separate battery? Meaning... the neg lead on one battery and the pos lead on the other battery? Or, do I connect both leads to just one of the batteries?
    2. Which mode (6-volt or 12-volt) do I set/use on the 40amp portable charger when doing this?
  • A pair of 6s in series is a 12. Put the pos clamp on the free post of one 6 and the neg clamp on the free post of the other 6. Use charger 12v this way.
    Actually, if the batts are installed in the rig with the neg post of one 6 grounded to the rig's frame,(which ought to be the case) then you are supposed to put the charger's neg clamp on the frame too, and put the pos clamp on the other 6's free pos post. (no sparks, safer)
    If you have a Trimetric that safe way will not show up as any amps returned. So you need to clamp to the outer end of the shunt to get your charging amps and AH returned figures.
    That's what I thought. Thank you very much for your quick reply. I'm not an expert with this, so I didn't want to mess anything up.
