time2roll
Dec 15, 2017Nomad
If you want to charge with the vehicle just get some big jumper cables and go direct battery to battery and let it idle. Need #4 wire for best results. Or just buy the wire and make your own. Still need to idle for one or two hours to get some charge in a low battery. Charging takes time.
The other side is conservation. You need a solid 12 volts to run the fridge and water pump etc but they do not draw a lot. The real hog is incandescent lights. If you have LED you will do far better. Consider just using flashlights or some portable lanterns. Do not use the furnace, bring warm bedding or bags.
Renting a Honda 2000 is a viable option.
You cannot remove the battery or the fridge will stop working. You would have to get a second battery to charge all day while you drive.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
