time2roll
Jun 25, 2015Nomad
WFCO 55, single battery and Honda 1000 is not going to be efficient.
You need 14.2+ volts to be efficient with time and fuel. If the WFCO ever by some miracle went to boost mode it would promptly overload the generator. You really need a 30 to 40 amp charger with the Honda 1000. (40 amp max) Really should replace the converter or get a portable charger.
Going as is... use both. WFCO will supply some good amps initially but with voltage limited to 13.6 will have amps tapering quickly over 70% charge. The 8 amps from the Honda DC connector will then continue at a moderate slow rate.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
