MEXICOWANDERER
Jun 26, 2015Explorer
I just did a comparison test between my WhiffCo and the Megawatt.
When the WhiffCo raised voltage to 13.6, I shut it off and started the Megawatt which was set at 14.8 volts. From 2.3 amps charging to 25.7 amps charging.
Now, that sorta says something dont'cha think?
The OP is running a generator. Save the Wiffie until the rig can find a power pedestal. That is unless the sound of a generator sucking three
and a half dollar a gallon fuel turns you on. Megawatt will set a person back less than twenty gallons worth of fuel minus a large bottle of aspirin.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
