landyacht318
Jun 26, 2015Explorer
I have a Meanwell, similar to the megawatt capable of 40 amps. I can change voltage simply by twisting a dial. I also have an Ammeter on the output.
When my single 12v battery is in the ~75% charged range, at 14.5v it will be taking about 35 amps, and if I drop the voltage to 13.6v the battery only accepts about 3 to 5 amps, if that.
So generator charging and the Wiffco are not a good match as the MegaWatt set at 14.4+v, will do much more for a single 27, using less generator fuel. You can also dial the voltage all the way up just to forestall the amps from tapering as battery voltage approaches the mid 14 range and pressure differential is less.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
