NinerBikes
Jun 26, 2015Explorer
smkettner wrote:
I doubt even 16 volts from any 30 amp supply will overload the Honda 1000.
I can tell you that 10% ethanol at 7500 feet and 14.8V with that MegaWatt 30 amp alongside the Madison River in Montana on a 17F morning on 9-11-14 had the meanwell at first on a warm motor sucking 40 amps and in 15 seconds, it was down to 33 and in another 15 seconds it was down to 29 amps, and there was one heavily taxed and loud barking EU1000i pumping all the beans in the tank for 30 seconds before the throttle on Eco mode just barely subsided. I do not know the PFC correction for the Power supply unit, but that generator is rated 1000 watts at sea level. 7 x .036 = 25%, that's 25% loss due to elevation, if you corrected the jets for elevation. You can throw away another 5% easily with cr@ppy 10% methanol in your gas too. So now you are talking maybe 700 to 750 watts, peak, from losses camping high up and with cut fuel.
At start up, on a 60% SOC battery, it will pull 40 amps, probably at 13.1V at the battery, it will be 14.8 at the PSU. That's 600 watts. That's very close to the limit, where I was. I saw the red light flickering as the amps maxed, and dissappeared in about 7 or 8 seconds as the intial amps surge dropped off.
It's pretty close, a lot like a Iota 30 amp at 14.8V being hard on an Eu1000i under less than perfect conditions.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
