NinerBikes
Jun 28, 2015Explorer
smkettner wrote:
If the 30 amp supply actually does 40 amps.... yes the Honda 1000 will struggle and possibly overload in certain conditions.
True 30 amp limited such as IOTA should be good in all conditions.
mexicowanderer thinks it was the capacitors that needed charging up to capacity before hooking to the battery terminals, that caused the high reading. So maybe it's not as hard on the Eu1000i as I observed, if you change your procedure. I don't leave my MegaWatt attached to the battery when not in use.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
