Naio
Jun 28, 2015Explorer II
landyacht318 wrote:
Naio, how many amps do you need/ desire?
The meanwell/megawatts have very small voltage adjustment dials requiring insertion of a jewelers screwdriver and a fine touch,
Ohhhh.. I had no idea!
So nobody makes an adjustable one that is meant to be adjusted all the time? In my dreams it would also have a timer, also easy to set.
Some solar controllers do what I want, yes? I can program them to do X amps for Y minutes and then Z amps for Q minutes?
And of course they are not automatic and can overcharge if set too high and left on too long.
I would, too. But I could set an alarm on my phone.
The Meanwell SE-350-15 has the constant current limiting feature which makes it good as a battery charger.
MW SP-480-15
RSP-500-15
The middle number is the rated wattage. They exceed this by 25% or so, my rsp500-15 will do 600 watts.
The second number indicates their voltage range median point.
My RSP 500 15 specs 33.4 amps and a range of 13.5 to 16.5v
It actually does 40 amps and its voltage range is 13.12 to 19.23v.
Thank you :))).
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
