NinerBikes
Jun 28, 2015Explorer
mitch5252 wrote:
I have a single Group 27 battery. I love to dry camp. I have a Honda eu1000i generator and a wfco (?) 55 power center.
which is the most efficient way to charge the battery - connect the battery directly to the battery or plug the trailer into the generator, or neither is better - they would both charge at the same rate?
Thanks.
You have a single group 27 Deep cycle rated at what 85 to 90 Amp hours. Half of that is 45 amps, that is useable. You'd be better off with a group 27 not getting it discharged much below 60% SOC. .4 x 90 amps would be 36 amps used. You'll get to 90% SOC with some efficiency with your Eu1000i, so replacing .3 x 90 should be your goal if weekending it, with a full top off recharge to 15V or more when you get back from camping.
So you are looking at replacing 27 amps, maybe 36 if you did a 50% SOC discharge cycle.
What I would do is buy the MegaWatt 30 amp model, it already comes with a cord and an on off switch, set the voltage on it at 14.8 or just a hair above that, 14.9V, with it fully disconnected from the battery, make a set of charging cables, and install an inline RC watt meter to the charging cables. Run the Honda until you are at a 7 or 8 amp rate of charge take rate to the battery, and then shut the generator off. Do this while camping.
Plug in your WFCO when you get home to the trailer, and let that run for 3 days at 13.8V to top charge the battery, then disconnect the battery for full time storage, and also disconnect the trailer and it's electrical to the WFCO. You should be fine.
Every camper should own a digital multi meter and a hand held amp meter, as well as a good high industrial grade hydrometer for battery maintenance purposes.
When your group 27 dies,strongly consider replacing it with a pair of GC-2 6 volt golf cart batteries wired in series, if you do much dry camping off the grid, which it sounds like you do, if you already have the Honda EU1000i.
