pnichols
Jun 28, 2015Explorer II
MrWizard wrote:
considering their "intended" use.. most likley was too be set once, and left alone
Not tinkered with and adjusted all the time
If I had one, I'd adjust it only once - but want to do it using a big ol' knob with graduations on it.
I'd adjust it with my coach battery bank reading around 12.0 volts at rest. Then I'd fire up the 650 watt Honda, plug the power supply into the Honda, then attach the power supply with big ol' wire to the battery bank with the voltage knob set to about 1/4 of maximum. Then I'd begin turning the knob in the higher voltage direction until the Honda just sounded burdened.
I'd leave the knob permanently at that setting for those particular batteries and that particular generator.
