wa8yxm
Jun 25, 2019Explorer III
BlueBoy wrote:
Will my Honda 2000 charge the battery as fast on eco as it will fill throttle?
Depends on how you are charging.
The cables to plug into the honda and clamp on the battery. Toss 'em
A small converter (Say 45 amp) will charge much faster and may well work in ECO mode. 60 I'm not sure if ECO will do it. 80 likely Eco won't. but .. it might.
And that's all there is to it. Depends on the size of your converter. Plug the RV in and see if the Unit hangs in there in ECO mode. if it stalls.. then switch to full for an hour and try ECO again. Odds are after 1-2 horus Eco will hold. Takes about 6-8 to fill the batteries no matter the mode.
NOTE: Why does ECO mode work after an hour or two if it won't first blush.. As the batteries fill up the current slows down and thus the converter does not draw as much power .
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
