BFL13
Jun 25, 2019Explorer II
There is the engine conking out and there is the circuit breaker popping. Not the same thing.
If you hit the Honda with a good load when the engine is cold, it will conk out whether in Eco or not. The trick is to let the engine warm up a little (a minute) before plugging in the load. It will warm up faster if not in Eco.
It doesn't matter about Eco or not to pop the circuit breaker with an overload.
To run my 100 amp PF corrected charger on the EU3000is Honda on a cold day, I had to start the Honda, wait a minute, then plug in the charger. The 100 amp was not a full load so no problem with circuit breaker. However, if I plugged in the charger too soon, the engine conked out. It worked better to start with Eco off, wait a minute, plug in and then turn Eco on once it is all running. No need to wait for the load to become less.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
