pianotuna
Jun 25, 2019Nomad III
Whether an 80 amp charger (converter) can be powered by a Honda 2k (really 1.6 k) VA may be due to power factor.
My PD is small at 35 amps--but the power factor is .7. So it can draw up to about 750 watts.
On the other hand, my inverter charger can do 127 amps on an 1800 watt supply because the power factor is 1. It is also temperature compensated.
I have no troubles running the charger from eco mode--partly because the Yamaha Sieb does have a way to do a 500 watt surge for 7 seconds iirc.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
