BFL13
Jun 25, 2019Explorer II
A curiosity in all this, is that the input required is related to the output at the time and that output is greatly affected by the battery voltage at the time.
So when starting the Honda to recharge a battery, the battery is likely low in voltage, which makes it easier to start the Honda.
The maximum input required is just as the battery reaches Absorption Voltage while the charger is still at its current limit. That is the time of max output. After that amps taper, so output watts decline too, reducing the input requirement from the Honda.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
