MEXICOWANDERER
Jun 25, 2019Explorer
The 3000is (?) I tested was thoroughly warmed up both tests
The Meanwell RSP is a Pf corrected machine
Connecting to a generator derived charging source robs current from the generator FIELD The rotor the shaft that spins in the middle. This is like using exhaust gas to jack up a rig. Illogical.
When I soft ramp loaded the Honda with the Meanwell the generator would start on the economy idle setting. Some pricey inverter chargers may or may not have a ramped charger loading circuit. I made my own from discrete components.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
