BFL13
Jun 25, 2019Explorer II
MEXICOWANDERER wrote:
The 3000is (?) I tested was thoroughly warmed up both tests
The Meanwell RSP is a Pf corrected machine
Connecting to a generator derived charging source robs current from the generator FIELD The rotor the shaft that spins in the middle. This is like using exhaust gas to jack up a rig. Illogical.
When I soft ramp loaded the Honda with the Meanwell the generator would start on the economy idle setting. Some pricey inverter chargers may or may not have a ramped charger loading circuit. I made my own from discrete components.
Interesting from Mex on how adding the load makes the engine conk out in certain circumstances.
In my case the difference was between a warmed up engine and a cold engine. In his case, with the engine warmed up both times, the difference was in the gasoline having more energy so the engine didn't conk out.
I see that in my case, starting with Eco off to get the engine warmed up faster than at lower revs with it on, may have hidden the Eco on /off comparison for whether the engine would more likely conk out with the same load and gasoline.
Ramping up the load to prevent a stall is an other thing besides IMO. I don't know how the generator is designed for that, but I have seen how my 100 amp charger's amps output ramps up from the low 90s to stabilize at 103 amps on start up. I thought that was the battery acceptance changing as the battery warmed up from receiving a charge, but it might also be something in the charger's design, don't have a clue.
In all cases, the answer to the OP is still that you can't charge the battery faster with Eco off. Faster charging requires higher amps over a shorter time and the inverter circuit breaker will pop at the same limit whether Eco is on or off when you try the higher amps.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
