opnspaces
Feb 14, 2020Navigator III
I prefer to use the Hopkins (#47185) 4 way to 7 way plug. I installed one on my Suburban back in 2005 and ran it for almost 15 years. I like it because it plugs into the existing 4 way flat plug to convert the lights to a 7 way. You then only have to run a brake wire from your brake controller under the dash to the plug at the bumper. The best part of the connector is that it also retains the 4 way flat so you can tow a utility trailer without using an adapter.
Link
Link
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
