Bobbo
Feb 15, 2020Explorer III
opnspaces wrote:
@Homeskillet-Can you please resize your picture to no more than 480 high? As it is now we are forced to scroll side to side to read the posts in this thread. If you edit your post and add height=480 to the link for the picture it should resize. If you do a quote on this post you can see where I added a height = 200 on mine.
Thanks
I use width=640 on mine. (Or whatever value I am shooting for, sometimes 320.) Same result. But, you added spaces within your text "height = 200", when it must be "height=200". It is actually not the height that is causing the problem, it is the width, that is why I use the "width=???" instead.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
