time2roll
Feb 15, 2020Nomad
Mark_Naturist_Camper wrote:In hindsight the flat 4 might work fine for the very intermittent power needed for this brake system. Mostly you are just running on the trailer battery.
I am installing a brake controller on my trailer. Among other things this thing allows me to connect my camper with trailer brakes to a Flat-4 Hookup. The link is below. My question is the way the thing gets power with the flat-4 is the running lights power. If I simply Jumper the 12VDC line from the Running lights line in my 7-way (Camper) to 4-flat adapter (Car) adapter will it work Okay and also charge the coach batteries. Or will it blow up? (Melt wires/blow fuses)
I'm looking for anyone that has tried to charge coach batteries, or simply powered a refrigerator, from a flat-4 running lights lead, (running lights must be turned on).
Best to start with a mostly full charge trailer battery. Bring an extra vehicle fuse for the running lights. Although unless you create a dead short the long thin wire will mostly limit the current to a tolerable level.
If you plan to camp off-grid and expect this system to recharge your trailer battery.... it will not do well. Solar would be a good option for camping and driving in the sun.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
