Dakota98
Sep 09, 2014Explorer
The charger is working correctly.
The voltage you were reading was what the charger was putting into the battery to bring it back up to capacity. Once the battery gets near to 100% the charger will then switch to a trickle charge mode. I have a "smart" charger that starts out at about 13.2 volts & cycles in small increments up to 16.0 volts over the charging period, once the battery reaches capacity, the charger senses this & backs down voltage.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
