atreis wrote:
joebedford wrote:
I guess I'm not explaining myself properly or my idea is just too stupid. The bus is dragging the toad down the road; the toad's wheels are turning; the toad's motor(s) are turning - throw in a little regenerative braking on the toad and its battery will charge. The bus has to work a bit harder but there is no modification to the bus.
Convenient, yes. Efficient, no. You're effectively charging your electric car from a gas generator. Your bus's engine has to work that much harder to overcome the increased resistance of the toad as it generates electric. (Sorry, no 1st law violations allowed.) In terms of efficiency, you'd be better off towing a hybrid or charging from mains at your destination.
Charging as you pull it down the highway? A sure miss because of the extra force needed. But for every time you take off in the MH, sooner or later you will need to "waste" some force getting it stopped. I think most use the toad's service brakes for part of this along with service brakes of MH. If when you want to slow down you could switch on the battery as load for the wheel driven generators, (motors when battery power is used to drive wheels) at least some of waste force could be stored in battery.
From what little I understand of E cars, power out of battery is used to move the car. Then some of the power is put back in battery by regn braking when you slow. Because it always takes more out when you start, and as you go, the battery will always discharge, but at a slower rate then if you did not use regenerative braking. Now if the power to take off and hold your speed is coming from MH engine, the braking could put more energy in battery than removing.
