Darklock wrote:
What is recommended for battery life if TT is used every three months or so? Trickle charger? Battery tender?
Removing a cable or having a master battery switch should be fine for three months.
However the battery needs to be tip top 100% charged. Many converters will take a long time and possibly never 100% charge the battery. Leaving it plugged in for several days at home and then removing the cable is the best bet. Or just leave it plugged in.
Post your converter model number for best suggestions.
