Darklock's avatar
Darklock
Charging issues?
Let me start by saying, it may be a while before I actually go out and look at the issue. Depends on current weather.
I use my TT a couple times each year. I always plug it up to the house for a day to get the fridge cool before any trip. Last few trips I noticed that once I unplugged, the 12 volt stuff did not work. Connect to truck and they do. After a short drive everything seems to work as it should, and continues to do so for the entire trip. These trips were anywhere from one to four weeks in duration.
What do I need to look at? Like I said , it may be a while before I can actually work on it, so follow up questions could be a ways off.
  • From the description it sounds like you allow the battery to discharge flat dead while not in use. Now the battery is shot.
    You will need to replace the battery and keep it charged.
  • First charge battery using stand alone charger, then have it load tested.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
