red31
Apr 26, 2015Explorer
rob_g wrote:
it can't sense anything at the end, hence it doesn't go on.
Why can't your PWM controller sense anyting?
If the battery voltage is low
(under 12.5V - this test will not work if the SunGuard is regulating
in PWM), then measure the solar voltage and battery
voltage close to the SunGuard. If the voltages are within a few
tenths of volts, the array is charging the battery. If the solar
voltage is close to 20 volts and the battery voltage is low, the
controller is not charging the battery and may be damaged.
I get it there is something between the batter and the controller:S
