dclark1946
Jul 20, 2014Explorer
pianotuna wrote:
Hi,
The converter with wizard does "look" at the battery voltage when first plugging in. It may start at 14.4 volts if that voltage is too low. However, once it starts at 14.4 in four hours it will drop back to 13.6. That is why I called it more of a timer than a sensor.
If recharging is needed from a genny it is more effective to "force" the 14.4 voltage.
The generator is more reliable until you run out of gas. My system does 7 amps at solar noon in leafy shade. If I did not use the inverter I would never run out of electricity.
I get 8-9 days of dry camping on 2 gal of gas with our Eu1000.
Dick
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
