pianotuna
Jul 21, 2014Nomad III
Hi Chilli,
In the summer in unshaded conditions I "see" 17 amps at solar noon, if the batteries are hungry enough or there is inverter use. Based on 5 solar "hours" per day that leaves me with about 85 amp hours going into the battery bank
7 amps means about 40% of the maximum possible. 85 x .4 = 34 amp-hours per day.
My system has 256 watts of panels and a blue sky 3024 di controller with a temperature sensor (I believe the temperature sensor is a MUST DO).
In actual fact, the solar probably does better than the above calculations as it stopped charging at 9 p.m. on 2014 07 21. That means that all parasitic loads are absent for 15 hours per day, as the panels provide the energy so needed.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
