otrfun's avatar
otrfun
Explorer II
Oct 14, 2014
Charging RV batteries with TV
In a pinch (generator, solar, goes south), what's the best/safest way to charge 1 or 2 RV batteries with a truck's alternator?
Simply parallel the RV batteries with the truck's battery with a pair of jumper cables? Or, disconnect the truck's battery and give full charge current to the RV batteries?
How much charge current can a typical truck alternator produce?
Thanks!
  • I would go with HD jump cables with #4 or better copper wire.
    Still going to need a solid three hours to get a decent charge into a super low battery.
  • Don't disconnect the truck batteries. They consume almost no current unless they too are discharged (also they will not limit current to the RV battery) and you run a chance of seriously damaging the trucks charging system.
    Simply using jumper cables will work but the amount of current delivered is strongly related to how good the connection is.
    Also, make the jumper connections BEFORE you start the vehicle. The spark from connecting it afterward can kill electronic systems in the truck. (Same for jumping another vehicle)
  • We had to use jumper cables for a week , it got us through. The easiest efficient way would be to take the battery out of the truck and replace it with the RV battery. That way the truck would not reduce charging due to the trucks battery not being low.
    Long ago I would have started the truck, hooked up the cables and disconnect one of the truck battery cables but that truck had no electronics like newer trucks so I'm not so sure it would be a good idea.
    The last possibility would be to hook up the cables and let everything sit for a few minutes. You would have to be careful if the rigs battery was too low as the two batteries will try to equalize but done right, the trucks battery should be pulled down a bit so that you would get better charging on the rig battery.
Having RV issues? Connect with others who have been in your shoes.24,331 PostsLatest Activity: Nov 04, 2025
