time2roll
Aug 12, 2013Nomad
It is normal for all to be wired to charge. Although verify that it is functioning. The long wire from one battery to the other will have some resistance and cause voltage to drop and limit the amps. #10 wire minimum for decent results. You may have 185 amps available but the voltage drop or an open circuit is probably hurting performance.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
