red31
Aug 13, 2013Explorer
vladio
One option is to disconnect the fridge from the trailer battery so it does not get discharged (leave the trailer break away connected).
Each inch of wire and every connection (battery (both), fuse/circuit breaker (@both batteries), ring terminal crimps, 7 blade connector, ... can be an issue. They need to be clean and secure.
Volt meter readings at the trailer battery and 12v terminal block on the fridge while operating can be helpful.
If your 115 watt fridge is draining the trailer battery, make a change.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
