TomG2
Aug 25, 2013Explorer
".....When we bought the bigger, newer pop up with all the bells and whistles I ran a heavy line off the positive of the battery along with installing a circuit breaker........"
As others have mentioned, it is easy to verify that you are getting a charge from the tow vehicle by comparing the trailer battery voltage unhooked and hooked with the motor running. It should show at least one volt higher. Having said that, and rereading your original post, I would also want to verify that there is a good ground connection between the two units. Just running a line off the + terminal of the battery is only half the connection required.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
