red31
Aug 29, 2013Explorer
Don't forget the other side of the circuit needs to be just as big a wire or bigger. With 5 or 6 function of the 7 blade connector all using the same ground it needs to be as big/bigger than the charge line.
There is no requirement that the fridge run off the PU battery, just a spinning alternator. IDK what the min required voltage at the fridg's 12v terminal block but it should be measured with the tv connected and fridge off and on.
Of course ya gotta start out with a health and charged battery to raise the roof.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
