STBRetired wrote:
Have you verified that there is 12V present at your 7 pin connector? Mine originally did not. There was a wire connected to pin 4 but no voltage present. Traced the wire back and it went to an auxiliary fuse panel but was not connected. My Brake Buddy would kill the battery in about 6 hours. Connected the wire and installed a 20A fuse. No more problems.
I checked that right after the shop finished the install. I'll check it again. I would suspect the RVi brake, but it's been mostly highway driving.
