wa8yxm wrote:
The correct way to charge them is to leave them in series and treat them EXACTLY as you would a 12 volt battery (Size 4D in case that matters). There are no six volt batteries in RV's. only 12 volt batteries that are shipped in two pieces to make them easier to wrangle.
Yes, I do understand that and will try using the Schumacher in 12V mode to charge the batteries in series. The reason I tried charging them individually in 6V mode is that when I used the Schumacher on my group 24 Interstate, the voltage never even got to 14 and then it went to float with my hydrometer showing only about a 90% charge. If there's one thing I've learned here, it's that you'll kill a battery in a hurry leaving it like that!
