RDMueller's avatar
RDMueller
Charging voltage for T-105s
Continuing my quest to learn everything I can about batteries and charging...
Moved on from the group 24 Interstate, may mess with it more later. Also put the hydrometer with the floating balls where it belongs - under the rear dual. Then I tossed Pinocchio (the EZ-Red) and got a real hydrometer.
The batteries - two brand new Trojan T-105s, fully charged. SG in all six cells was 1.275 - 1.280, temp 70F. Put them in series and applied a 12A load for 6 hours bringing the SOC down to about 60-65% and measured the SG at about 1.205. Then separated them to charge individually. The charger I currently have is a Schumacher SC-10030A which is 30A and can do 6V/12V.
Bulk charging began at about 6.5V and rose over the next few hours to about 7.1V and then stayed there for a while. So far so good. Trojan says absorption should be at 7.4V so my concern was that it would never get that high, since that seems to be the most common problem. Boy was I was surprised when the next time I looked, the voltage was 8.1V! Even their recommended equalization charge is only 7.75V, so I turned it off but first got this video:
T-105 video
I have read here that some bubbling is good, but you don't want it to be a "rolling boil." Rather than try to guess which I have, I posted the video to see what you guys think.
I still plan to go full manual in the future with a Megawatt or Meanwell. In the mean time however, the Schumacher is what I have and I wanted to give it a chance to see how it performs. Like I said, I figured if anything it wouldn't ever get high enough, I sure wasn't expecting 8.1! Next, I'll try switching it to 12V and charging them both together in series.
My overall goal is to take really good care of these batteries so they will last me a long time. I don't want my battery vendor sending me free calendars!
Having RV issues? Connect with others who have been in your shoes.24,295 PostsLatest Activity: Aug 04, 2025
