mattherrington's avatar
Apr 10, 2018
Charging While Towing
Newbie to the forum here. Looked around a bit and didn't see anything specific so worth a fresh post.
We just took our first long trip in my 16ft TT after I installed a new (4)6-volt 460AH system in lieu of the single group 27 marine battery. Installed a Victron 700-BVM which was/is the coolest gadget. Love the AH consumed/charged function as that and voltage were my real measurements of state of charge. Didn't quite like the percentage used so that'll take a little programming change (hopefully).
Overall on the six night trip we used 170AH with the kids watching DVDs every night, ending voltage when we got home was around 12.25V. Pretty respectable. Just the smoke detector, carbon monoxide, propane detector, propane fridge controls, and a USB that stays hot draws about .85A an hour and if we were out for the day I'd just shut it down.
To my surprise though I didn't get the charge I thought I would when we were out on the road. We relocated twice 2-3 hours each and drove home 8 hours yesterday and the change in AH and voltage was seemingly negligible each time.
I've got a 30A lead wired from a empty fuse slot to the 7-pin connector. My big battery system install is right to the original connection points on the TT to keep things simple. When I start the truck I can see the Amps inbound to the trailer peak at about 5A but then really quickly it dropped down to 1/0/-.85. The AH meter moves backwards and forwards so I recorded a little dent in AH used right at startup but that was it.
My simple math said even at 5A inbound I'd see a real dent in total AH consumed on our crazy long drive home and it was at 175AH when we left and 171AH when we got home. Every time it basically felt like it was a wash and I thought I'd see a 30-40AH pickup after a whole day on the road. Truck voltage the whole ride was considerably above (runs around 13.4 to 13.6 on the move) the trailer batteries in the mid/low 12's.
Only thing I can come up with is that I run full lights on (lights on for safety!) all the time and the running/marker/brake lights on the trailer are still incandescent and that's consuming most of that trailer feed?
Seems like I'm missing something. Any insight from you experienced folk would be appreciated.
  • Inverter in the engine compartment dubious due to heat. When idling, hood up, inverter on fender by battery, it quit from overheating. Had to hang the inverter out over the fender to get it away from engine heat.
  • When I need to charge while towing, I fire up my little blue friend and let it run in the truck bed. it gets plenty of cooling while in motion, and you can't hear it at all once at highway speed.
  • brulaz wrote:
    So installed a left-over 1000W inverter in the truck (which has a 220A alternator). Good for other things too (like charging tool batteries), but primarily use it to run a 650W battery charger in the trailer. Added an extension cord with water tight couplings between truck and trailer and we're good.
    theoldwizard1 wrote:
    That will work ! Not as "clean"/simple install as a DC-DC charger, but if you have the "left-over" inverter, it IS less expensive !
    brulaz wrote:
    One advantage is that you can use an existing more sophisticated 120VAC charger in the trailer. One with temperature compensation and multi-stage charging.
    The CTEK D250SA DC > DC Charger is specifically designed for this purpose and includes temperature compensated charging. :B
    SoundGuy wrote:
    Curious - did you install the inverter under the hood or elsewhere, how long is the run to the inverter input, what input cable gauge did you use, and did you connect directly to the starting battery or elsewhere? :@
    brulaz wrote:
    Its in the bed of the truck on a shelf behind the cab and under the cap.
    Didn't want the hassle of putting it in the cab ...
    And I didn't trust the heat and possible water in the engine compartment.
    The wires are some extra 6 awg I had around, with a 60A Maxi fuse and 140A (13.3V on, 12.8V off) Princess Auto isolator.
    The + and - wires comes off the truck's passenger side battery terminal (diesel truck with 2 batteries)...
    I've got the same Motomaster inverter, currently mounted in the trailer's front pass through cargo compartment, so thanks for the info ... I'll have to muse on this as an option. :B
  • I have a constant duty solenoid and 150A breaker under the truck hood going to a 2ga run to the receiver with an Anderson connector. My trailer batteries also have have 150A breaker to a short 2ga run and Anderson connector on the tongue so I get better vehicle charging.
    My setup is slightly different because I also run 2-way power to my truck camper and have two banks of batteries in my truck in addition to the bank in the trailer.
    As was already posted, it does not fully recharge my battery bank but it will bring it up before shore power or solar top them off with an intelligent charger.
  • profdant139 wrote:
    For someone who says he's electricity dumb, you sound like you are doing quite well! Just FYI, I have a similar trailer (even smaller), and we get along great with a 120 watt portable solar -- plug and play, easy to use, store, and deploy. There are pluses and minuses to rooftop systems (or should I say positives and negatives?).
    Also, replace those incandescent bulbs with warm white LEDs asap -- big savings on juice!
    And welcome to the forums! What kind of a trailer do you have, and where are you going next?
    It's a 2015 Pacific Coachworks Mighty Lite 16BB that somehow didn't sell, got repo'd, something and went to auction where it got bought/flipped to me last summer. Had all the manuals, dealer prep delivery checklists, but couldn't find a scratch on it. I was really just picking around for a 3,000 lb trailer with bunks AND a full and as few moving pieces as possible. Somehow I got it matching my rig!
    This electricity thing was just my second real mod. First was to upsize from those scary 14" pizza cutters to a D-rated 215/75R15 LT tire, over/under the axle, and mount some Monroe gas shocks under there all with the intent of dragging it down a bunch of off road trails.
    Next up is some dispersed wilderness near Sequoia NP and down into Kings Canyon NP by the river.
    A very nice, clean installation ! As long as you understand the limitations of your system and can live with them, you are fine.
    Personally, I would go withe the CTEK D250SA DC > DC Charger. They make an add-on device that can do high current charging if your TV can make the power.
  • Is that battery box vented to the outside?
    And a sealed plastic box perhaps to protect against spills?
    My previous trailer had two GC2s in a plastic box inside, with maybe 2" flexible plastic hose out the top, maybe 2' long, going to the outside.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
