twistedsistersr
Sep 30, 2014Explorer
Yes - it only happens when going down the road with nothing on. I have no generator and don't run anything inside while camping at this point.
I have a sure power box with fins isolator with 3 prongs. When I got the RV - wires were already on the posts marked 2 and A so I left them. I connected the house battery (which was not installed when I bought it) onto post marked 1 as it was the only one empty.
After the issues on the trip - I decided I woudld try connecting the opposite way - Chasis on 1 and house on 2 but the wires are not long enough to do that so I would "assume" that it was never connected that way. There were "jumper" wires connected when I got teh RV so could they have been jumpering posts 1 and 2 to accomplish proper connections?
I will definately take the RV up to Pep Boys and have the altinator tested. In addition....I was thinking of purchasing a new isolator and new wiring and running it all new so I knew exactly what went to where without question.
Parked with shore power everything is fine....If I don't run the fridge. I have a 3 way fridge that does not currently work on LP. I don't run it unless on shore power but it still seems to kill the battery - and oddly enough - the chasis battery, not the house battery which is confusing as it is wired directly to the house battery.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
