dougrainer
May 16, 2013Nomad
Your year DIP may NOT have the dual charging system relay control. The control is located at the LF side storage where the large fuse bank is located. The fuse board has a spot for that controller, but not all Monaco's had the controller(the more expensive Sig series did) and if you do not, you can add it. If you post a pic of that large fuse board, I can tell you if your unit has the controller. Later on Monaco did install the controller on the DIP/Camelot models. Doug
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
