YC_1
May 17, 2013Nomad
YC 1 wrote:
1.
2.
3.
See if any of this helps you along. Since it DID work you probably have a bad combining solenoid. Often called the BIRD relay. There is lots of reading in the links and once you get a bit more familiar with the operation you may be able to help us help you. There are pictures in some of those links.
Click number 1, scroll down to Tompen and look at the module. You will see it has a generator input.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
