Went to crank up our motorhome the other day to run it for a little and run the generator. The chassis battery was dead. Had to start it with the switch that draws from the house batteries. Let it run...
I usually put it on my B&D VEC1093DBD portable charger and let it do its magic for a couple of days. Then throw it away in the core pile. Seems like for me once they get run down that bad they are history.
I usually leave my batteries sitting on the trailer but totally switched off-line. You probably got hit by some parasitic battery drain..
NOTE: once they get run down then they are prone to freeze as stated in below post...
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
