MrWizard
Jun 29, 2015Moderator
some body wired something wrong..
those items should be connected to the ignition run circuit, NOT the chassis disconnect relay
somebody some time got some wires wrong when repairing or replacing something
start with a chiltons book for that chassis, and trace those wires and move them to the right connections
it won't cover the RV side of the wiring, and it most likely will not show the chassis disconnect
but it will show wire numbers , size, color, code and where those wires for the wipers etc are supposed to be connected
most likely one BUSS wire 10~8ga that was moved from One terminal to the wrong one
Do you have (2) disconnect switches ? house and chassis ?
not all rvs disconnect the chassis, almost all can disconnect the HOUSE aka Coach
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
