jjrbus
May 08, 2016Explorer
Kayteg1 wrote:jjrbus wrote:
Thanks for the response. Very simple actually, I have a decent quality tire gauge and a inflator with a pressure gauge. Use one than the other.
In all the years I have been doing this only one time has a tire gauge went bad and that was recently.
My inflator is a cheap one from Harbor Freight, I simply replaced the pressure gauge on it with a quality one that I can see the numbers on and put my dual foot chuck on it from the now defunct tire gauge.
HTH Jim
http://www.harborfreight.com/dual-chuck-tire-inflator-with-dial-gauge-68271.html
The linked chuck would not work on my coach as I have no space for putting it at angle for inner one. I had to get one with straight tip.
Than I have identical set made in USA. The older gauge is 10 psi off. I know I can pull the needle and reset it, but I simply remember to inflate 10psi higher.
Chinese can manufacture top quality stuff, but US customers or at least US suppliers don't want to pay the price, but ebay is having direct contact with Chinese sellers, so check their top shelf systems.
I have the same issue, and have to use the straight foot to access the inner duals. So now I have a couple of the angled ones in the spare parts bin. Many of these items use standard threads and can be interchanged.
Jim
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
