tewitt1949's avatar
tewitt1949
Explorer II
Sep 18, 2018
Cheap Refrigerator question
I'm thinking about buying a cheap refrigerator to replace the junk one in our travel trailer which has been a problem for years.
Anyways, Do the engineers who make refrigerators design them to last a certain number of hours of use? Like vacuum cleaners and many other things now days, they will fail after a certain number of hours used? I should mention I'm talking about house refrigerators.
My question, In theory... if cheap refrigerators are designed to last just saying 3-4 years of continuous use, and since we only use our travel trailer maybe 3-4 weeks a year, will a cheap refrigerator last more than the 3-4 years since it will be shut off 90% of the time? I realize moisture and humidity and corrosion could be a factor also.
At my age I don't need one to last 20 years, if it will last 10 years I'd be happy. So why spend $1000 on one if a $350 refrigerator will last just as long being used very little.
  • How are you going to use it? Will you be stationary and plugged in all the time, if so just go by the manufacturers installation guidelines.
    If traveling you will need an inverter to change 12 volts dc into 120 v ac. If dry camping you Will need an appropriate battery bank and a way to recharge effectively.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
